No spark after going through 3 distys.
Locked
Tyler17rose
Re: No spark after going through 3 distys.
Post by Tyler17rose »
Make sure your grounds are all intact.
Mods:
DavidOS
Post by DavidOS »
make sure the plugs goto the disty in the right order
Zoso124
Post by Zoso124 »
Read all your voltages back at the ECU with Ignition on and off. You can find this all in the troubleshooting part of the manual.
Mike Evans
Gone:
Locked
