engine codes
engine codes
heyy I am not sure how to tell the difference between all the different engines if anyone can put a list if all those short forms
and I have heard that there is like 3 different type of KLZE and one of them is really good is that true? if so which one is it and once again how do u tell the difference
Re: engine codes
ANY klze is really good. The curved neck IM ze has a few less hp, but it fits our cars(without modification), so in the end it works out.
<small>[ September 12, 2004, 11:36 AM: Message edited by: mxmaz ]</small>
- bmwm3guy
Re: engine codes
<img src="http://www.barrykclark.com/pix/usesearch.gif" alt=" - " />
Try searching first dude... there are tons of topics about info on how to identify the motors. Chekc the FAQ section I believe there is a post or two.
The KLZE comes with the Straight Neck, or the Curved Neck manifolds. The CurveNeck fits easier and without modification. The StraightNeck requires a Master Cyclinder swap/modification.
<small>[ September 12, 2004, 08:45 AM: Message edited by: bmwm3guy ]</small>
Re: engine codes
but the rest besides the master cylinder fits all right in, like the wiring harness and the mounts right
sorry about posting stuff that was already discussed, I wasnt sure how to use the site yet
Re: engine codes
try checking this page: http://www.geocities.com/viv95pgt/klze.html
daytona blue MX-3 2.5L V6 KL-ZE, KL31 ecu, koni lowered 40mm, freeflow exhaust system (decat), centerforge race clutch, cold air intake Dynamik, front and rear strut bars reactive, OBX race headers, Akebono pro act ceramic brake pads, Techna fit steel brake lines, zimmmerman crossdrilled rotors, reverse glow gauges, spinner gauges, topmix front lip, pakfeifer skirts, pakfeifer difussor, pakfeifer wing, inverted scoop bonnet , 17" bsa rims, etc
Re: engine codes
It's not that hard to use the longneck intake manifold. I might write a faq with pictures for it, since we've done it 3 times before without any major problems, you just have to modify some stuff.
Bastian
Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
Re: engine codes
To Bastian
I`d really like too know how to make the straight neck IM fit. Could you tell me it. Just a little write up (dont have to be very detailed).
Klze,CAI,Exedy clutch, HM Engine mounts, HM ss exhaust system,Cobra lowering springs, 18" wheels.
Re: engine codes
Sebastian just quick write up would help a lot if u dont mind, I am hoping to start this week in getting this done, so if u dont mind give me an e-mail or something on how to complete this swap thanks Danny.
what kind of master will I be needing with the streight intake manifold?
- bmwm3guy
Re: engine codes
Use an MX6 96 Master Cylinder, and relocate the brake fluid resevoir so to let the IM fit.
Re: engine codes
ok thanks I can get an mx6 master and I can just attach the reservour via a hose and locate it anywhere there is room under the hood
Re: engine codes
So if you use that approach, there is no tilting of the engine or TB modifications? And can the master come only from a 96 mx6 or can it come from any 93-97? what about one from a probe?Originally posted by bmwm3guy:
Sorry for all the questions but i'm trying to get this clear.
<small>[ September 12, 2004, 06:13 PM: Message edited by: mxmaz ]</small>
Re: engine codes
It looks like there are two connections between reservoir and master cylinder, as there are two independant circuits. The reservoir should be mounted at least as high as the original,because it's a gravity feed to the MC.Originally posted by Sick_Mx3:
Also, when you fill the system, you need the hoses to fall all the way from the reservoir to the MC, to eliminate bubbles. After it's filled, you can secure the reservoir and allow a bit of hose droop, as long as the bottom of the reservoir is above the top of the MC.
<small>[ September 13, 2004, 07:46 AM: Message edited by: IanL ]</small>
Re: engine codes
apparently the curved neck delivers more power anyways so why bother wasting time installing the long neck one?
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Re: engine codes
In my case i have the kfze engine and it probably won't be easy selling that IM and if it does sell i won't get nothing for it. So i want to fit the long neck kfze IM that already on the engine to save $$$.Originally posted by Gro Harlem:
