Sputtering
Posted: September 6th, 2004, 8:34 am
by 93mx3v6
seems to sputter when in lower and mid range rpm... i think its the spark plugs/wires or distributor... its either sputters and or has gaps in its acceleration... i dont know if its the wiring or a fule problem of some sort. what do you guys think?
Re: Sputtering
Posted: September 6th, 2004, 9:46 am
by Chasing_Size
funny, i got the exact same problem yesterday when i threw a ms8 manifold/TB on....
Re: Sputtering
Posted: September 6th, 2004, 4:32 pm
by IanL
95% probability it's vacuum leak. Check the ribbed hose between the VAF and the TB first.
Re: Sputtering
Posted: September 7th, 2004, 8:39 am
by 93mx3v6
shouldent be vacuume hose or leak, i just replaced that stuff and its tight, it was sucked out before then i fixed that, now its a different feeling than before...
Re: Sputtering
Posted: September 7th, 2004, 10:01 am
by TsiMiata
Could be a bad O2 sensor. A check of the engine codes will tell you.
Re: Sputtering
Posted: September 7th, 2004, 6:15 pm
by 93mx3v6
ill get it checked before i do anything i suppose... my friend has a diagnostic computer
Re: Sputtering
Posted: September 8th, 2004, 8:08 am
by TsiMiata
It's easy enough to check yourself. Just put a jumper wire between ten & grn on the diagnostic connector and turn the car on. The check engine light will flash the code. The connector is right next to the brake booster under the hood.
Re: Sputtering
Posted: September 8th, 2004, 11:14 am
by endocyc
This is good info for any MX-3 owner to know. also clearing of the computers memeory. Disconect the negative battery terminal and press the brake for 10 seconds. This will whipe all codes from its memory.
