ze and k8 fuel rails
- babyblueMX3
are k8 and klze fuel rails the same size..I got a spare k8 fuel rail here that I could polish and then swap over on my milli mani..I think they are the same but not sure..just checking with you guys
RIP 400whp ZE-T MX-3
- papa roached
Re: ze and k8 fuel rails
they are the same, just the injector sizes are different
Would it make a difference in performance if you have the K8 fuel rail on the curved neck ze manifold? Thats what I have on mine cause I accidentally broke the connectors on the fuel rail.
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
Once again. THE V6 FUEL RAILS ARE ALL THE SAME. INJECTORS ARE DIFFERENT.Originally posted by MX3ze@7psi:
- babyblueMX3
thanks guys..guess I'll start polishing :p
