Page 1 of 2
Emissions problem :(
Posted: September 3rd, 2004, 4:07 pm
by kev259
I just got my klze put in a month ago, (replaced a couple things(New o2 sensors, etc.) I went to get the exaust put on today and get the emission's done...Well it failed off the charts. I have a magnaflow cat, and hotshot headers. I came back home, checked the computer and it came up with code 24 and 17, which are both o2 sensors! This all happened after I had the cat and muffler put on. Any ideas?
Re: Emissions problem :(
Posted: September 3rd, 2004, 5:26 pm
by TsiMiata
You didn't go with single wire O2's did you?
Posted: September 3rd, 2004, 5:29 pm
by kev259
Man I didn't, I was a little confused with the whole thing
I just went out and checked it looks like all the wires are hooked up right...
Posted: September 3rd, 2004, 5:57 pm
by johnnyb
are you using ngk universals?
if so go to this link:
Here
and hook up the wires like case #2 the exact same colors are found on your stock wiring so just reference it and hook it up like that
Posted: September 3rd, 2004, 6:30 pm
by kev259
They are bosch, I checked it out and looks like all the colors are good. My ratings were...
15 mph...HC ppm limit 119, my readin 587
co% limit .67 my reading 11.09
The NO ppm passed real low so that not the problem...Could this be my o2 sensors messing up?
Posted: September 3rd, 2004, 7:00 pm
by lakersfan1
Are those at idle, 2500 RPM, what? I'd clear those codes and drive around and try and pull codes again.
What O2 sensors did you use? Universal 4 wire or with OEM plug? If Universal, did you solder the contact points? Or just those stupid retarded connectors that come with Bosch universals? I don't trust those connectors because you can't even see if you're making full contact.
Then, if you eliminate the O2 sensors, I'd pull the timing cover off and go over your timing marks. Check them once, check em twice, check em thrice.
<small>[ September 03, 2004, 06:00 PM: Message edited by: lakersfan1 ]</small>
Posted: September 3rd, 2004, 7:08 pm
by kev259
Yeah I used the universal one with 4 wires...Maybe I should use something else besides the wire harness? I'll give that a try tomorrow see what happens...thanks
Posted: September 3rd, 2004, 7:25 pm
by lakersfan1
I used solder and heatshrink, followed by sliding the stock expandable sleeving back over the wires.
Posted: September 3rd, 2004, 9:36 pm
by SimonPK
what VAF are you using because if you are using the K8 you will get those codes.
Posted: September 3rd, 2004, 11:59 pm
by kev259
The VAF I have is whatever came with the car...I have a jspec ecu, but everything else is the same.
Posted: September 4th, 2004, 12:31 am
by lakersfan1
So using the correct VAF will give you codes?
Posted: September 4th, 2004, 12:40 pm
by SimonPK
when I put my KLZE in it ran great for a little while around town with the K8 VAF but horrible mileage on gas - I went on the highway and codes came up after I was cruising for about 20 minutes & they were the O2 sensors - shortly after I did my emmissions test in BC and failed. It was recommended that I buy a VAF from a KLDE 2.5 which is what I did and evreything was then perfect.
Only trying to help!!!!!!!!!!!!!!!
Posted: September 4th, 2004, 12:41 pm
by SimonPK
Posted: September 4th, 2004, 7:22 pm
by IanL
Which ECU are you using?
Posted: September 5th, 2004, 10:30 pm
by kev259
It's a kl07(from a probe but with a modied jpec chip...)I'm going to redo the wiring, but should I look into the vaf for a 2.5?
