hi guys...
i have a quick question regarding the fitment of the G25-r lsd box do you have to upgrade the hubs as well, then using bigger brakes or can we use the standard hubs we already have on our cars?
any help would be appreciated..
thankyou
Lsd Gearbox kl-ze
mdavis
Re: Lsd Gearbox kl-ze
Yes but installation is nuts and I think you have to custom modify the splines on your axels... could be wrong though...
GS-R SE
Fixin's
Why not just get the phantom grip I have one it works and functionally its design is the same as any other LSD. Your just adding it to your existing setup instead of altogether changing the diff
I believe Gro Harlem did LSD. U should ask him.
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
