RPM cut off @ 5500
your2slow
RPM cut off @ 5500
Post by your2slow »
Hey all, just wondering what would cause a total loss of power @ 5500 RPM. I've got a 96 mx-3(OBDII)runing with a kl-ze and in first gear when i hit 5500 RPM there is no more pull, the RPMs keep going up but no pull what-so-ever. 2nd, 3rd,4th and 5th seem to be fine but 1st just cuts out. Here is some info on my ride
Stock 1.8 ECU
Stock VAF
KL-ZE
ZE IM
New headers with 2.5 from the CAT
2 O2 sensors (should be 4 but new headers only had spots for 2)
??? anything else that you need let me know. Just wanna know if anyone else has this issue with thier ZE.
<small>[ August 07, 2004, 07:21 PM: Message edited by: your2slow ]</small>
KL-ZE, Custom Intake, Apex Lowering Springs, and more to come this year.
Toronto Mx-3 Club
My Cardomain Site
hgallegos915
Re: RPM cut off @ 5500
Post by hgallegos915 »
I have heard issues with people having problems while using a k8 ecu. I thinik you need to get the klze ecu. not sure bout it yet.. i havent done the swap myself.
-hec
papa roached
Post by papa roached »
you ever think of nabing a OBD II KL-DE VAF, im running a OBD1 K8 ECU and KL-DE VAF because thats as good as you can get of a combo save for a ZE ecu or have you tried getting the KL-DE ECU too?
I'm not too sure about OBDII Mx-3, but when i was running my K8 ECU it was running extremenly rich and drinking gas
IanL
Post by IanL »
Here's a logical deduction - it does not have to be correct, but it could be:
The ECU does not know what gear you are in - there is no instrumentation in a MTX to tell it. All it knows is Neutral or not-Neutral. So maybe the Neutral Switch in the tranny is out of adjustment and is saying neutral when you are in first? That could cause the ECU to restrict torque.
You can test this theory by unplugging the Neutral Switch connector. Then the engine will always think you are in gear.
your2slow
Post by your2slow »
Hmmm I'm going to try that. Never even thought of this.
Toronto Mx-3 Club
My Cardomain Site
Tempus
Post by Tempus »
Is the neutral switch normally open, and gets closed only when the trans is in neutral? if so your test should work fine. A better alternative might be if you have a multi-meter and a few clip leads. You should be able to disconnect the switch, connect the meter to it, and observe if the switch is open or closed in all possible positions of the trans.. (all 6 gears, and all 3 neutral positions (left, center, right)) to see if everything is behaving as it should. That test can be done sitting still :)
{sigh} Time to move on
Out with the old: Tropical Emerald MX-3 GSR (KL-DE)
In with the new: Phantom Blue Mazda3s GT
IanL
Post by IanL »
Yes, it is only closed when in neutral, and that's an excellent idea, if it shows the problem up. But it did occur to me that it may only show when the box is transmitting torque (if the condition is marginal) so, if the test shows no problem, it would not be conclusive.
Gro Harlem
Post by Gro Harlem »
get an AFPR...its the one thing I still need to realize the full potential of my ZE too...i can't squeeze any power past 6500.
DONATE TO MX-3.COM
IanL
Post by IanL »
Are you suggesting that the lack of power above 5,500 rpm, but only in first gear, is caused by fuel starvation? I'm not saying you're wrong, but why only in first?
<small>[ August 09, 2004, 08:17 AM: Message edited by: IanL ]</small>
MrMX3
Post by MrMX3 »
where abouts is the neutral switch on the tranny, mine started doing the same thing and was working fine for a while....
Mike
1993 MX-3 GS
2.5l KL-ZE
My Cardomain Page
IanL
Post by IanL »
It seems from the manual to be below and slightly in front of the right side driveshaft, with a cable which leads rearwards and upwards.
