Cold AIr intake Q
Cold AIr intake Q
Whats up guys - quick question, just got a cold air intake from street-import.com, and i am not sure if the intake will connect to all the stock connectors that relay information from the stock intake. My question is, what connections(wires, tubes, etc.) do i scrap when installing this intake, and what connections get reinstalled to the new cold air intake? Thanks legends
Re: Cold AIr intake Q
Did you get the PRM?
- PATDIESEL
You put a breather filter on the large tube on the motor side and scrap the piece that goes to the intake. There should be one other vaccum hose and it must still connect to the intake pre-MAF (VAF)
