auto engine w/ 5spd tranny
- DJester187
is there any kind of sensor that is on the ze that is programed/acting for auto tranny that would affect my idle/acceleration?
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
Re: auto engine w/ 5spd tranny
No. If you've got the ECU for a manual, you should be fine as far as sensors go. The only thing different from a manual and auto engine is the fly wheel. You put the flywheel for the manual on before you strap the manual tranny up, and you're good to go.
It is recommended that u resurface the flywheel and about the idle..no it shouldnt o.0 if u got an outo the code for um I believe (not sure) neutral start switch , the one that doesnt let the car start if its not in parking or neutral.
-hec
