clutch pedal squeeks
like the subject says my clutch pedal squeeks when i let it in, and makes the same squeek again when i let it out. I've been reading other similar posts and couldnt find a clear answer. Is this something that a shot of grease will take care of or could it be something worse?
Re: clutch pedal squeeks
Happens to my cars sometimes. Shot of lithium grease should work, assuming that squeak is just the pedal assembly. You can make sure by operating/listening to the clutch pedal with the motor off & if it squeaks then it probably needs a little lube at the pivot point. Once had my wife going nuts searching for seagulls over our car driving thru mountains cuz she didn't know I was making the seagull noises by easing the clutch pedal in/out just right.
