Supercharged KL-DE or KL-ZE???
- MX-3 Money
Just want some thoughts on this, so all are welcome. What would you guys think is better a supercharged DE or a regular ZE? I know that the ZE has a higher compression ratio so the super charger or a tubro wouldn't get as good boost? Anyone have a supercharged DE out there anyways? And for me the DE would be cheaper(before the supercharger) and better to pass emissions.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
- babyblueMX3
Re: Supercharged KL-DE or KL-ZE???
jeff abrams used to have a SC klde but switch to a turbocharge DE...If he did this probably he tought it was better...I would still rather have a good tuned ze than a DE supercharged..that's my opinion
RIP 400whp ZE-T MX-3
TsiMiata
A US spec millenia engine would be best. All the advantages of the ZE(heads and intake manifold) with the compression of the DE.
91 Eagle Talon Tsi AWD *RIP*
Nallboy
Just to clarify, the ZE is HARDER to boost, BUT it would provide better boost: higher c/r = more hp per psi of boost. It just requires more precise tuning than say a DE with low compression cams (ie. 8.5:1).Originally posted by MX-3 Money:
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
y not just supercharge the K8... if boost is on all the time there is no need for more power off boost right?
i could be wrong... but thats just what i thought of.
-Damian
***if u know of/have a mx-3 GS with a blown engine and live around me... let me know
- babyblueMX3
supercharging a k8 would be the same as dropping a ze in imo
Nallboy
It prob would be close to the same HP, but TQ...? I still think modding a K8 is a waste of money when compared to a ZE swap.
- babyblueMX3
amenOriginally posted by Nallboy:
I don't know how a regular Kl-ze runs, but you should have driven my turbocharged K8 when it ran!!!!! It had a kick in the @ss at 4K that was scary!!
European Mx3 GsRT
- johnnyb
well with the new ZE's that have been popping up here and there from the millenias in Japan it would be more worth your while to get that one IMO.... 9.2:1 compression ratio, 190 hp to start imagine the advantage over those DE's with Turbos or Supers in respect to potential
Millenia in japan
<small>[ July 09, 2004, 06:14 PM: Message edited by: johnnyb ]</small>
Millenia in japan
Try this link
