1.8 top speed?
pickinganame
1.8 top speed?
Post by pickinganame »
i was just woundering what is the fastest someone has took there 1.8 till it was at its top speed just curious... :)
Trevor
Re: 1.8 top speed?
Post by Trevor »
why don't u figure it out with ur's
lol
at a closed track of course
fIyingchopstick
Re: 1.8 top speed?
Post by fIyingchopstick »
138 mph :: cough cough :: on a track of course... hehe.. This took quite a long time to do also.. So I wouldnt recommend trying it..
138mph
" fo shizzle my nizzle "
lakersfan1
Re: 1.8 top speed?
Post by lakersfan1 »
About 130's the highest I went. Had a bit left on the tachometer, but didn't want to push my luck since I was starting to come out of unpopulated desert area into metro area. Just ran up to touch it, then dropped back to cruising speed (100mph). I could see 138 on the speedo with a tailwind. Not sure how accurate the speedo is, though.
MX3-Freak
Re: 1.8 top speed?
Post by MX3-Freak »
The abosolute top speed of a k-8 completely stock is about 127 mph. This is fugured out by red line, gear ratio and tire size. If you have larger tires, you will go faster, but your speedo will read slower.
Anyways, a k-8 with stock tranny and rims will go no faster then about 127mph without exceeding the redline. Everyone's 130 claims are slighlty inaccurate speedos (Check your odometer in a five mile test and you will see I'm right); mazda isnt perfect.
<small>[ June 21, 2004, 08:40 PM: Message edited by: MX3-Freak ]</small>
Stock 1995 RS - Creek Blue
Car Meanins:
ssmog
Re: 1.8 top speed?
Post by ssmog »
Will have to get a complete dyno done when I take my mx-3 in for an e-test this summer because according to my speedo I have had mine up to 235 km/h.....in English that's what?....approx. 140.3 m/h? Mind you that was on a nice open road with not much to dodge but the odd piece of road kill.
Commit yourself to a Psychiatric hospital before the rest your sanity disappears, and you are strapped in a chair, fed mushy peas with a rubber spoon with only your tortured fantasies for comfort....
ssmog
ninjasteve
Re: 1.8 top speed?
Post by ninjasteve »
i had mine up to around 210 km/h so around 131mph and i was still accelerating slowly but i had to slow down cuz i was coming up behind someone.....yes....on a track.....
RoundTop
Re: 1.8 top speed?
Post by RoundTop »
I've only had my stock MX-3 GS up to 105MPH so far..had to slow down due to upcomming traffic... was still accellerating when I pulled off.
No, I was not on a track.
valdigre
Re: 1.8 top speed?
Post by valdigre »
Well I did 200 km/h (about 124 mph) and it was with the engine speed of 6500 rpms... So I had like 700 more rpms spared meaning I would probably do the suggested 210 km/h (130 mph). I still don't know if Iyingchopstick's mx-3 is stock but it seems unbeliveable to reach that high speed with standard one.
Anyways i reached mine on normal road...It was empty though but imagine how focused i was... :driver:
"For those 10 seconds or less, I am free"
SIXPACK
Re: 1.8 top speed?
Post by SIXPACK »
I got 210 km/h on my 15" stock rims and winter tires. it would be fun to have a 6th gear :D
Black '92 GS - Pacesetter QuickShift w. SRD Extension rod Bushing + bronzoil - Top Speed Pro1 exhaust - Hotshot style headers - GTS coilovers - 18" ADR Sokudo gunmetal, f+r strutbar, floorbar & SRD crossmember
Gro Harlem
Re: 1.8 top speed?
Post by Gro Harlem »
i've nver had mine past 115....i don't really care how fast it can go, as long as its fast enough to keep up with traffic on the highway.
Top speed should be 132 according to the tire size, gear ratio, final drive & RPM limit, of course it'll go up higher b/c of the fuel cutoff which is around 7400rpm. By then you should be up past 140 a little bit.
My 626 tranny should allow me to surpass 150 if I try, but I won't b/c its stupid revving your car that high for such a prolonged period of time since it takes a long time for your engine to overcome the wind resistance and crap.
DONATE TO MX-3.COM
killerpickle
Re: 1.8 top speed?
Post by killerpickle »
i believe fuel cut off was 7800 was it not?
Tom Alexander
fIyingchopstick
Re: 1.8 top speed?
My car was all stock at the time accept for a full catback and k&n in the box.. It was with 95k on the odometer.. And I've hit somewhere around 132-135 every time after that with upwards of 150k on the odometer..
mitmaks
Re: 1.8 top speed?
Post by mitmaks »
had mine at 126mph last summer
Re: 1.8 top speed?
isnt the k8 governed at 190km/h? When i tried once with my k8 i topped at 190km/h and couldn't go any faster
