Vacuum hoses on CAI.
lakersfan1
Post by lakersfan1 »
OK. On the Integra intake I bought, there are two bungs for vacuum line. The smaller one seems to be the right size, however, the larger one isn't as big as the vacuum line that's T'd into the accordian section right now. So how do I get it to work? If I just tapped a hold and pulled the plastic fitting out of the accordian, can I just shove it in the new CAI tube? I've searched the archives, and didn't see any answer to the resolution on this question.
babyblueMX3
Re: Vacuum hoses on CAI.
Post by babyblueMX3 »
the big vacuum line goes INSIDE the existing line..It will hold without a problem
RIP 400whp ZE-T MX-3
babyblueMX3
killerpickle
Post by killerpickle »
what year integra intake fits again?
Tom Alexander
drift
Post by drift »
Babybluemx3's picture is the same way I have mine, except it managed to get the hose over the stock fitting. It was a PITA, and took me half an hour, but I managed to get it on.
lakersfan1
So you're saying I was supposed to get some kind of hose with the kit? The intake I got was a remnant from my brother-in-law selling his Integra. He took all the parts he could reuse. I've just got the metal tube, wiht the rubber couplers on order from Pep Boys. :shrug:
babyblueMX3
yup the blue (big vacuum) was supose the come with it..It would help a lot to have it :p
oh and the intake is 90-93 acura intake
lakersfan1
I'm not too keen on the looks of that setup with a tube inside a tub, then having the vent on the other side. Does anyone know where I might be able to find a proper sized fitting and weld it on myself, or maybe even anyone know if a muffler shop might have various fittings they could weld on in shop? I know there fittings on a cat. converter, but not sure if all of them are the same size, and if they're all already fitted to the cat or if sometimes they need to try new ones?? Any ideas of where I can find fittings like that in metal, and what applications they might be used in?
