Hi guys got two questions..I'm having a hard time with my tranny this week and decided to check the fluid of my tranny..how on earth do you check it..is it the same fluid as the brakes? because I don't see anywhere else you can check...
question 2: how do you bleed a clutch...I have to install my stainless steel clutch line but will have to bleed the clutch after...A good and detail description would be apreciated?
thanx
clutch bleed?
- babyblueMX3
clutch bleed?
RIP 400whp ZE-T MX-3
- jpwmx3
Re: clutch bleed?
If you have a manual transmission, you can't check your fluid level/color ,like an automatic. You just drain/replace fluid from the side of transmission via drain plug.
1993 GS V6/402,000km http://images.cardomain.com/member_imag ... 290_18.jpg
- babyblueMX3
Re: clutch bleed?
nice now need an answer for number 2
