Louding Ticking only on when cold
Hi guys. I havent been on the site for a while because I had to move form Canada back home. I am now in the process of getting my car ready to go back on the road. I was just wondering, I put in a KLZE last summer and I noticed that whenever I go to start the car after its been sitting for a while, i.e when its cold, there is a really loud ticking noise but as soon as it warms up it goes away. Any ideas on what it may be? Thanks
- papa roached
Re: Louding Ticking only on when cold
when the oil is cold and thick your lifters will tick a bit
yup. Normal--usually.
So you guys say lifters but does that mean I have to replace them because it onyl happens on the rear bank and toward sthe number one cylinder. Really weird if you aks me.
Oh yeah thanks for the input by the way.
- mitmaks
you can of course replace lifters but its not gonna be cheap
You can try to clean them which may quiet them some. Try the one at www.Auto-RX.com Expensive, but is gentle, and stays in the system for a couple thousand miles.
Then, after that, you can try messing with different oils like sythetic vs. dinosaur and different brands and different viscocities. Most in cold areas go 5W-30.
![Werd :werd:](./images/smilies/werd.gif)
I have used Auto-RX and let me tell you, this stuff is miraculous. Quieter valvetrain, seals leaks (as long as your seals aren't torn), more MPG and longer engine life...
Go with Valvoline Maxlife after the treatment(s) for a few thousand and your engine will be sparkling inside....
10W30 in summer, 5W30 in winter
that's for everywhere except Canada and Alaska...
93 White MX-3 "Ebay special"
94 Green 626 V6 5-speed "family car"
94 Mazda B2300 SE "project turbo truk"
whats wrong with 10w-30 in the summer and 5w-30 in the winter in canada??
I would likely run 5W30 all year long in climates that average below that of more moderate climates such as where I live in North Carolina. Here our summers avg 90+ degrees F and our winters never get below 10 degrees F so I run 10W30 in summertime...Originally posted by Jon_Carnie:
- jpwmx3
Does everyone from the US think Canadians live in igloo's year round. LOL
We have temps in the 90's in the summer too.![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
1993 GS V6/402,000km http://images.cardomain.com/member_imag ... 290_18.jpg
- papa roached
one day a year dont count :p just messin
LOLOriginally posted by jpwmx3:
We have temps in the 90's in the summer too.![]()
I guess so. How many days are 90+ where you live in the summer?
i thought u guys live in ice caves in the great white north, igloos are reserved for alaskansOriginally posted by jpwmx3:
![Laugh :laugh:](./images/smilies/laugh.gif)
