Would the KL throttle body work on K8 mani
Would the KL throttle body work on the K8 intake manifold?
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
- babyblueMX3
Re: Would the KL throttle body work on K8 mani
your answer is probably here
RIP 400whp ZE-T MX-3
You can use any one off a curved neck intake manifold. The Millenia is the only U.S. spec car with the IAC and coolant lines on the proper sides. You can also get a KLZE throttle body if it's off a curve neck manifold as the IAC and coolant will also be on the proper sides. However, the IAC doesn't have a vaccuum line on the KLZE, so you'll have to plug the corresponding vaccuum hose on your intake manifold.
