KL 36 ecu
Posted: March 20th, 2004, 1:48 pm
by mightym0use5
I was wonedering if anyone knew where pin 1M is located at. I tried searching but i could not find anything. i don't have a chart on the back of my ecu that tells me which pin is what.
Re: KL 36 ecu
Posted: March 20th, 2004, 2:19 pm
by mightym0use5
it is the pin that takes the speed limiter of the ecu.
Re: KL 36 ecu
Posted: March 20th, 2004, 3:45 pm
by curtklze
the speed limiter is there for a reason, you should leave it alone.
Re: KL 36 ecu
Posted: March 20th, 2004, 9:47 pm
by TsiMiata
It's there because japanese law requires it. Since we don't live in japan theres no need to keep it.
Re: KL 36 ecu
Posted: March 20th, 2004, 10:57 pm
by dewthis
IIRC, the connector closest to the firwall is the #1 port and the letters start from the top. The letter A is at the top B below it and C is right beside A. Someone should back me up on this but I'm pretty sure this is correct. If you go to PT they have a sticky about the pinouts, the only difference is the probe is rotated where the pinouts are facing the console. Hope this helps.
Re: KL 36 ecu
Posted: March 21st, 2004, 12:51 pm
by mightym0use5
I found out it is a black and whit wire. on the top row, fifth from the firewall. -I cut it and everything works fine on my dash. I have not gotten a chance to go that fast yet, but hopefully it worked. I'll post it when i do. Thanks for the help.
Re: KL 36 ecu
Posted: March 21st, 2004, 1:57 pm
by curtklze
which race trak do you race at? I want to take my car that fast but there is no track around here with a straight away long enough.
Re: KL 36 ecu
Posted: March 21st, 2004, 2:14 pm
by aaronthehic
it's marked on the circuit board inside the ecu
Re: KL 36 ecu
Posted: April 12th, 2004, 11:58 pm
by mightym0use5
I just wanted to add that it does work. I was able to hit 122 easy. Had to slow down for other reasons.
Re: KL 36 ecu
Posted: April 13th, 2004, 1:47 pm
by seneca
Sinner....
Re: KL 36 ecu
Posted: April 13th, 2004, 2:53 pm
by mx3man83
Good thread, I was searching for the location of that dang pin when I had the kl31 ecu. I hated not being able to go past 115(I think that was it). Temporarily, I have the probe gt ecu and vaf so I don't have a speed limiter. I am going to the dyno in a few weeks and I'm going to do a probe gt ecu and vaf vs. kl31 ecu and je50 vaf to see the actual differences between the two.
Re: KL 36 ecu
Posted: April 14th, 2004, 12:01 am
by Qalex
are u guys sure that it is not the 6th one from the firewall cause the other ones are pink,brown, etc... untill i reach the 6th which is black and white. oh and before i cut this wire is it a possitive thing and wont mess anything up besides my driving record?
