Camshafts ?
Posted: March 20th, 2004, 12:10 pm
by 88HP
Who makes them and where are they
Whats the specs on lift and duration for the V-6
Re: Camshafts ?
Posted: March 20th, 2004, 3:43 pm
by curtklze
mazda makes them as far as I know.
they are located on top of the cylinder heads, you have to remove the valve covers and the intake manifold to access the cams.
I dont know the duration or lift but if you use the search feature you could probably find out.
Re: Camshafts ?
Posted: March 20th, 2004, 5:22 pm
by babyblueMX3
this is taken directly from the mx-3quebec club
thanks to gsrbomb
MX-6 V6 93-97, Millenia 2.5 95-00*,626 V6 93-97,Probe GT V6 93-97:
Intake opens at 8 degrees BTDC
Intake closes at 47 degrees ABDC
Exhaust opens at 50 degrees BBDC
Exhaust closes at 5 degrees ATDC
626 V6 98-02:
Intake opens at 3 degrees BTDC
Intake closes at 42 degrees ABDC
KL cams are 244deg. @ 0,004 ", 196deg @ 0,050 ", 67deg @ 0,300 ". maximum lift is 0,338 ".
KLZE cams are 246deg @ 0,004 ", 200deg @ 0,050 ", 84deg @ 0,300 ". Maximum lift is 0,350 ".
Re: Camshafts ?
Posted: March 20th, 2004, 11:16 pm
by 88HP
The kl and kl-ze dont have much of a difference. What makes the ZE so much more powerfull?
where can you buy high performance CAMs for the Mx3?
Re: Camshafts ?
Posted: March 21st, 2004, 12:32 am
by lakersfan1
More compression and higher octane fuel.
Interprep makes high performance cams for the KL. I'm sure you can use them on the K8. Also, I've heard the KF-ZE have the most agressive cams of all the factory cam options, but good luck finding a set.
Re: Camshafts ?
Posted: March 21st, 2004, 5:16 am
by GuidoBiRiChiNo
There's a guy on ProbeTalk named Mike Seli, he sells cams for the KL.
I bought them and I will install them in a week or two!
Guido
Re: Camshafts ?
Posted: March 21st, 2004, 11:27 am
by 88HP
KL is the standard v6 american model?
Re: Camshafts ?
Posted: March 21st, 2004, 11:36 am
by Zoso124
KL-DE A-Spec
KL-ZE J-Spec
Re: Camshafts ?
Posted: March 21st, 2004, 11:39 am
by papa roached
can i get a link interprep
Re: Camshafts ?
Posted: March 21st, 2004, 11:49 am
by jaydog5678
Re: Camshafts ?
Posted: March 21st, 2004, 1:52 pm
by curtklze
better cams, better cylinder heads, better intake manifold, higher comperssion pistons, different ECU programing that is programmed with more spark advance to take advantage of all the better parts and to be used with 94 octain (= to 98 in japan)fuel.
The engine has a knock sensor if you use 87 or 91 the ECU can tell aand will produce less power, if you use 94-97 the computer will supply more spark advance and you will get more power.
Re: Camshafts ?
Posted: March 21st, 2004, 7:07 pm
by Zoso124
If you go with the Interprep set up your looking at $900 usd.
$600 Cams
$100 Shims
$144 Stiffer valve springs
Re: Camshafts ?
Posted: March 21st, 2004, 7:36 pm
by 88HP
1.8T..
is there an add on turbo as well, or is that a j-spec motor? And what's the cams internet site again?
How many 6 cylinder motors were made to fit MX3.
Re: Camshafts ?
Posted: March 21st, 2004, 10:18 pm
by lakersfan1
$600 Cams
$100 Shims
Crap! For that much, you could buy a KF-ZE and pay someone to install it.
