Whats the specs on lift and duration for the V-6
More compression and higher octane fuel.Originally posted by Chris Redmond:
What makes the ZE so much more powerfull?
KL-DE A-SpecOriginally posted by Chris Redmond:
KL is the standard v6 american model?
better cams, better cylinder heads, better intake manifold, higher comperssion pistons, different ECU programing that is programmed with more spark advance to take advantage of all the better parts and to be used with 94 octain (= to 98 in japan)fuel.Originally posted by Chris Redmond:
. What makes the ZE so much more powerfull?
Crap! For that much, you could buy a KF-ZE and pay someone to install it.Originally posted by Zoso124:
If you go with the Interprep set up your looking at $900 usd.
$600 Cams
$100 Shims
$144 Stiffer valve springs
