Half Shafts ??
Posted: March 14th, 2004, 10:44 pm
by mx34u2nve
Just wonderin if our axles are the same as the one on theprobe and mx6. I hear that the transmissions are. So basically what i'm getting at is can i get a LSD tranny from japan.. and use the MX3 STAGE 2 (300HP) axles with it.
Re: Half Shafts ??
Posted: March 14th, 2004, 11:41 pm
by Zoso124
PGT/MX6 axles have the same number of splines as the mx3 but they are longer since there are wider cars. The japan LSD will work but your going to have to find custom axles because they have more splines then our axles.
Re: Half Shafts ??
Posted: March 15th, 2004, 5:01 pm
by TsiMiata
Has anybody tried
www.raxles.com for the axles yet? That guy can make a half shaft that will fit anything.
He made custom ones for my friends miata. They adapted an RX-7 turbo rear end to his car. They were made from RX-7 inner joints, a mitsubishi shaft, then finally 323 GTX outer hubs.
