Half Shafts ??
mx34u2nve
Half Shafts ??
Post by mx34u2nve »
Just wonderin if our axles are the same as the one on theprobe and mx6. I hear that the transmissions are. So basically what i'm getting at is can i get a LSD tranny from japan.. and use the MX3 STAGE 2 (300HP) axles with it.
Turbo 2.5l mx3
Zoso124
Re: Half Shafts ??
Post by Zoso124 »
PGT/MX6 axles have the same number of splines as the mx3 but they are longer since there are wider cars. The japan LSD will work but your going to have to find custom axles because they have more splines then our axles.
Mike Evans
Gone:
TsiMiata
Re: Half Shafts ??
Post by TsiMiata »
Has anybody tried www.raxles.com for the axles yet? That guy can make a half shaft that will fit anything.
He made custom ones for my friends miata. They adapted an RX-7 turbo rear end to his car. They were made from RX-7 inner joints, a mitsubishi shaft, then finally 323 GTX outer hubs.
91 Eagle Talon Tsi AWD *RIP*
