with 18" wheels fit my car?
with thread that's 2**/35/18?
will 18" wheels fit my mx3
- mitmaks
Re: will 18" wheels fit my mx3
yes they will fit
wow, did this site have a search function?
Just make sure to get the correct offset and you'll be fine. Also i wouldnt go any wider then 8inch rims.
Mods:
What about calibrating the speedometer/odom?
- monstar-mx-3
you have to get the same diameter tires...for excahne if you have 205-55-15 tires.(15 rims) when you move up to 17, your prfole drops down to 45-15. you will have to get a 215-45-18 they will not effect the speedo
