BLUE SMOKE!!
93-Spec-Edn
BLUE SMOKE!!
Post by 93-Spec-Edn »
Hi
My gs is a little hard to start and when it does it blows a puff of blue smoke which immediately disappears. It runs soomthly and well and never blows blue smoke when started. Could leaky valve covers cause this??
92 mx-3 RS RIP | 95 mx-3 GS sold | 93 mx-3 GS SE sold | 95 mx-3 GS present
93-Spec-Edn
Re: BLUE SMOKE!!
ttt
IanL
Re: BLUE SMOKE!!
Post by IanL »
My guess is worn valve guides. Oil drips down valve stems when the engine is stopped, and pools on top of the valves. It enters the cylinders when the engine starts.
When you're running, it isn't enough to notice.
Gro Harlem
Re: BLUE SMOKE!!
Post by Gro Harlem »
bad valve seals if it doesn't burn it all the time. Have someone you know follow you when your on the highway, and downshift so the car revs at a high rpm....see if the person says that your car blows blue smoke, if it does, its teh valve seals which are a PITA to replace.
DONATE TO MX-3.COM
SimonPK
Re: BLUE SMOKE!!
Post by SimonPK »
I got a quote from a mechanic to do the valve seals on my old K8 and he wanted $800 per bank! So it's cheaper to run the car until it fails Emmissions / Aircare or whatever and then put a replacement engine in.
Steeb
Re: BLUE SMOKE!!
Post by Steeb »
800 to fix your k8?!?! good lord, you're in canada, pick up a ze instead. i have a set of k8 heads i can sell you if your interested. nothing removed
SimonPK
Re: BLUE SMOKE!!
Post by SimonPK »
thanks for the offer but I already did the ZE thing 6 months ago - best mod. ever!
93-Spec-Edn
Re: BLUE SMOKE!!
I still have 6 months warranty on the car. Shall I get it fixed? A whole rebuild?
