posible air conditioning help?
Hey all the other day I got into a lil fender bender. and basically when I turn my aircondiionaing on for my 93 4 cyl and I press the ac button it just blows out air from the outside and there r no visible leaks, any ideas what might have happened?
Re: posible air conditioning help?
check connections to your compressor and make sure your compressor is turning on... open hood get someone to turn on ac while u listen ull be able to hear it click on
hay the other day i was doing work on my mx3 and i acidently disloged the a/c wire from thr fuse box. that wire runs acrose the front of the car and is straped to the radaitor from there it runs in to the fuse box on the right side.note i had the same problem as u did beffore i realised that i had disloged this wire, and once i fixed it no problem. so check it out best of luck ![Wink ;)](./images/smilies/icon_wink.gif)
