looked and looked
- papa roached
looked and looked
i have looked but can find andthing on what pins your supposed to short to set engine timing and idle and if you guys know of some pics that would be helpful
- JdawgMx3er
Re: looked and looked
Hey Papa, check out the online shop manual,in the left hand column on MX-3s main page.Go to B2-Engine K8 DOHC,under Section,(left side of page),then on right side scroll to B2-008.(Engine Tune Up). Page B2-001 gives you the table of contents for everything on the K8 series engine. Hope this helps.
- papa roached
koo, thanx
