Is my engine dead?
Posted: October 31st, 2003, 10:21 am
by Jutzi420
Ok, I was making my weekly trip to school on the 401 highway this past sunday and 45 minutes in at about 130km/h my engine "popped", grey smoke everywhere, clouds of oil out the back, engine lurched and stalled. I just had a chance to lift the car up today and found a hole the size of my thumb in the oil pan.
I just want a few opinions on what damage would probably have been caused to the engine internals, and how much work it might be to fix. I was planning a ZE swap in about a year but I'm thinking it might be a good idea to just go for it now, any suggestions?
Re: Is my engine dead?
Posted: October 31st, 2003, 10:40 am
by guyaverage
If the whole is punctured outward, you probably broke a rod, which makes it ZE time.
Posted: October 31st, 2003, 10:43 am
by andy
going on what you said, It would cost more to fix it than to put a KLZE in. It sounds like you seized the motor up, wether the hole came from road debri or internal parts busting lose. the damage from oil starvation can be severe. You need to do a little more investigative work to find out just how severe.
Does the car still crank over? turn the crank by hand.
Andy P. 93 GS
Posted: October 31st, 2003, 11:10 am
by Jutzi420
Yeah I figured no matter what caused it, no oil at a high speed means new engine. The hole is punched outward, although I didn't hear the clanging that usually accompanies a rod break. How exactly do I turn over the crank by hand?
Posted: October 31st, 2003, 11:40 am
by andy
socket on the alternator nut, you might need to push down on the belt at the same time.
I would pull the spark plugs. that might also shed some light on which if any of the cylinders were damaged.
Andy P. 93 GS
Posted: October 31st, 2003, 11:44 am
by OsoSlo z28
to turn the crank by hand, you use a socket on the crank pully nut. not sure about the v6's, but the 4cyl can use the tire iron.
Posted: October 31st, 2003, 1:48 pm
by Jutzi420
Well, upon futher investigation I've found a few spare parts in the oil pan, seems it's time for a ZE. Oh well, I guess I'll just have to live with it.
Posted: November 3rd, 2003, 12:39 am
by papa roached
dont it suck when that happens :p
