Alright my friend on here has an MX-3 with a KL03 in it. He told me that by running the 1.8 V6 ecu, the engine can rev higher among other things, any of this true?
What else will running the 1.8 V6 ecu do?
Could I run it in my MX-6?
ECU Questions?
The G2 Racer
ECU Questions?
Anthony
MX6? Maybe soon.
I Can Install Parts And Build Custom CAIs.
[email]Gwathnar@hotmail.com" target="_blank[/email]
MX6? Maybe soon.
Re: ECU Questions?
The k8 ecu/kl vaf on a KLDE motor will produce more hp than the stock setup. The rev limit is however the same there is more timing advance in the k8 ecu programming.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
