heaedlight question
monstar-mx-3
heaedlight question
Post by monstar-mx-3 »
Ok..this is strange. having problem with my driver side headlight.<p>1-day time running lights- headlight is on
2-night driving light - Headlight is off
3-High Beams - Head light is on.<p>I looked at the bulb and it looks fine. Both elements are there! any help?
Zoso124
Re: heaedlight question
Post by Zoso124 »
Switch the headlight bulbs and see what happens then.
Mike Evans
Gone:
Taras
Post by Taras »
Can someone move this to an appropriate topic?
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
Falstaff
Post by Falstaff »
you daytime runners are your highbeams run through a 65 watt resistor. the filiment for your low beams is burnt out.
jnic
Post by jnic »
I have the same problem in reverse no daytime or high beam only normal lights.... I think my highs just burnt out and same with you just your normal ones burnt out
