rotor help
rotor help
i just had my new kvr drilled rotors with the kvr pads put on my car and when i drive it sounds like the pad is rubbing the rotor and when i brake it sounds like a hiss from a spray can is this because its new will it go away or is something wronge
Re: rotor help
Mine did the same thing. It just takes time to get them seasoned in. If you are that worried about it get it checked. Also have them accelerate the seasoning ...(grind the hell out of the edges) It took about 1000 miles for mine to go away. Take a few hard 70 to Zero mph stops a day. Not A "OMG A DEER" Stop ...just hard stops.<p>Cage
