KLZE ecu and VAF
davidosk024
KLZE ecu and VAF
Post by davidosk024 »
I read in a post awhile ago about the KLZE
ecu and the KLZE vaf.<p>From what i can tell after the swap and with
spare vafs and ecus laying around...<p>the K8 VAF is the same as the KLZE VAF (according to parts numbers this is)<p>the ECUS are completely different.... in your exp.
what works best with the KLZE VAF?? the KLZE ecu? or the K8 ecu?
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
Smokin mx-3
Re: KLZE ecu and VAF
Post by Smokin mx-3 »
kl-ze ecu is the best for the kl-ze engine
davidosk024
sweet,<p>and it should be plug and play basically yes?
In
Eunos 30x, v6
Smokin mx-3
ya it is plug and play
Cage
Post by Cage »
Unless it is the KL62 KL-ZE ECU, from a Eunos 800. That Ecu will not run a VAF it is designed to run a MAF.
eunosads
Post by eunosads »
David, what is the serial number of the ECU?
- EUNOS 30X -
davidosk024
umm
KL-36 i think
In
Eunos 30x, v6
dennisvs
Post by dennisvs »
eunos 800 needs a MAF ?
So klze from eunos = kl-ze ecu and eunos800 MAF ?
IanL
Post by IanL »
Potential for confusion. From what I've been told, the engine will run with a MAF or a VAF as long as it has the appropriate ECU for the sensor. But the MX-3's harness is built for a VAF, so you have to use a VAF (and therefore the ECU for a VAF).<p>If that's wrong, I'd like to know, please :)
eunosads
Post by eunosads »
that is correct from my understanding Ian.. <p>the ECU and the sensors go hand in hand.. as does the ECU and wiring harness.. as does the wiring harness and sensors.. <p>so.. if you want VAF, you need VAF ECU, VAF wiring harness.. and guess what.. a VAF sensor!!<p>same goes for MAF.. you need MAF ECU, MAF wiring harness, and a MAF sensor...<p>I've not heard of any MX-3's running a MAF, I think maybe the wiring harness would not suit.. not 100% on that one though.. <p>@ds
- EUNOS 30X -
aaronthehic
Post by aaronthehic »
any idea what the ze + 800 maf and harness dyno at?
13.023 @ 105 mph
