bore out a klze
Posted: February 16th, 2003, 7:33 am
by MXKreepscort
Any one know about how much horsepower I would get if I were to bore out a klze 2.5 to a 2.6, if it even possible, also how much would something like this cost?
Re: bore out a klze
Posted: February 16th, 2003, 12:00 pm
by pelado
HP gains from a marginal increase in displacement and CR would be minimal. Check with a local machine shop for how much they charge to bore a V-6 block. You would need new pistons and new rings, not to mention a few gaskets.
Do your own cost estimating:
www.importperformanceparts.com
Re: bore out a klze
Posted: February 16th, 2003, 6:12 pm
by davidosk024
Dude why only goto 2.6???<p>apparently the mechanics ive spoken to say the max they have bored out a ZE has been to 2.9<p>which is huge...
Re: bore out a klze
Posted: February 16th, 2003, 7:58 pm
by pelado
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by davidosk024:
Dude why only goto 2.6???<p>apparently the mechanics ive spoken to say the max they have bored out a ZE has been to 2.9<p>which is huge...<hr></blockquote><p>What did these guys use for pistons?<p>How many miles have accumulated on these engines bored out to 2.9?
Re: bore out a klze
Posted: February 17th, 2003, 12:49 am
by MXKreepscort
by "new pistons" do you mean brand new ZE pistons or some other after market ones for the ZE?
Re: bore out a klze
Posted: February 17th, 2003, 1:44 am
by VizualXTC
If you bore out the block you are taking material from the inner walls of the cylendars. This would result in the pistons not sealing because of the gaps that are produced. You will need custom made pistons to the specifications that the block now requires.
Re: bore out a klze
Posted: February 17th, 2003, 2:04 am
by davidosk024
yes that is correct
you need to get custom pistons,
i got a quote for that, for 6 forged
pistons to fit it would cost about 1500
bucks
Re: bore out a klze
Posted: February 17th, 2003, 2:27 am
by quinn_seipp
stroking the engine is probably where you could gain the most discplacement...
