bore out a klze
bore out a klze
Any one know about how much horsepower I would get if I were to bore out a klze 2.5 to a 2.6, if it even possible, also how much would something like this cost?
Re: bore out a klze
HP gains from a marginal increase in displacement and CR would be minimal. Check with a local machine shop for how much they charge to bore a V-6 block. You would need new pistons and new rings, not to mention a few gaskets.
Do your own cost estimating:
www.importperformanceparts.com
Re: bore out a klze
Dude why only goto 2.6???<p>apparently the mechanics ive spoken to say the max they have bored out a ZE has been to 2.9<p>which is huge...
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
Eunos 30x, v6
Re: bore out a klze
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by davidosk024:
Dude why only goto 2.6???<p>apparently the mechanics ive spoken to say the max they have bored out a ZE has been to 2.9<p>which is huge...<hr></blockquote><p>What did these guys use for pistons?<p>How many miles have accumulated on these engines bored out to 2.9?
Re: bore out a klze
by "new pistons" do you mean brand new ZE pistons or some other after market ones for the ZE?
Re: bore out a klze
If you bore out the block you are taking material from the inner walls of the cylendars. This would result in the pistons not sealing because of the gaps that are produced. You will need custom made pistons to the specifications that the block now requires.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
![Image](http://www.angelfire.com/ut2/vizualxtc/images/mx3_2.gif)
![Image](http://www.probetalk.com/forums/images/smilies/icon_spongebob.gif)
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: bore out a klze
yes that is correct
you need to get custom pistons,
i got a quote for that, for 6 forged
pistons to fit it would cost about 1500
bucks
bucks
In
Eunos 30x, v6
Eunos 30x, v6
Re: bore out a klze
stroking the engine is probably where you could gain the most discplacement...
130 hp and 1000 horsepower strong, ![Wink ;)](./images/smilies/icon_wink.gif)
