Clutch Problem!
Clutch Problem!
Ok, I just picked up my new MX-3.
Ok, so I was driving it, and It feels like no matter how far I push the clutch to the floor, the clutch feels like it is trying to grab... example when I am in first gear stopped, I have the clutch to the floor, and the car is shaking like its half ingaged, and grabbing!! Well anyways, I was driving home and BAM. All of a sudden, the clutch lost all feeling, yet it still does this in first gear, but I can shift fine in 2nd and 3rd<p>HELP!!!
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: Clutch Problem!
Could be the following:
-blown clutch line
-blown slave cylinder
-blown clutch master cylinder
-broken clutch fork
-toasted throwout bearing
-funky pressure plate issues<p>
I'd check them in about that order...
-blown clutch line
-broken clutch fork
David Coleman
Re: Clutch Problem!
Thanks Dave.
Sorry if my post is/was hard to read. I was trying to get all of it out at once
Re: Clutch Problem!
Ok, took it to Aamco today
Small leak in the slave cylinder, cause the flywheel to lose pressure when engaging the clutch, cuasing the to 2 rub. This cause hot spots. <p>he is charging me
$500 for the clutch and pressure plate
$85 for resurfacing the flywheel
$115 for a new Slave cylinder
4 hours labour
$80 Rear seal<p>Anyways, estimated total was $1113 CND, not including taxes
4 hours labour
Re: Clutch Problem!
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Talon_66:
4 hours labour
$80 Rear seal<p>Anyways, estimated total was $1113 CND, not including taxes<hr></blockquote><p>
Did you get vaseline for that reaming? <p>new slave cyl was ~50USD when I bought it in December. Clutch master cyl was another 75USD. You may or may not need a new clutch disc/pressure plate. You're getting taken to the cleaners...
4 hours labour
David Coleman
Re: Clutch Problem!
Damn man, you're get bent over a crate of mayonaise. (Dave got the "you're f'ed" joke in first)<p>I would suggest a Clutchmaster's Stage 1. I love CM, they take a beating and last a long time. Plus the stage one is practically stock and I believe its relatively cheap. As for all the other parts, well... you need to shop around for better prices because you should NOT be paying that much.
Re: Clutch Problem!
I saw both the flywheel and pressure plate, both have heat damage and are badly cracked. Aamco shares a lot, with the company I work for. So we do business with them all the time. I saw all the parts. But yeah it does seem high :S
Re: Clutch Problem!
Flywheels can be $50, I heard, from NAPA or online autoparts stores, do some searching there.<p>CM sends you a pressure plate, so its worth it if it needs replaced.
Re: Clutch Problem!
Hell, my clutch kit is $125 U.S. I can get it installed for $200 and the flywheel resurfaced for $30 You got ripped off man!!
Re: Clutch Problem!
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by David Coleman:
<p>
new slave cyl was ~50USD when I bought it in December. Clutch master cyl was another 75USD. <hr></blockquote><p>where u get the new slave cyl from???<p>
aj
<p>
aj
resurected KL-ZE,ZE ECU, 9lb Fidanza Flywheel, CMIII, home depot CAI, Hiflow Cat, 2 1/2" piping, exhaust, 2 MASS 2012's, Cadence A7, Blaupunkt Casablanca, and a no damn CEL light!!!
Re: Clutch Problem!
Just replaced a clutch, $225. resurfecing the flywheel involved nothing more than a 3-M sanding wheel to remove the glaze. The glaze always looks burnt, kinda blue/black/silver. If ya mail it to me I'll resurface it and it'll still be under $85 LOL. The parts you can price yourself from the dealer, probably the same price because he gets a discount to build in some profit. The clutch kit (Dynamax from any parts store) should not be more than $125. Watch UAP/NAPA, their prices can be very high for the same quality part. Shop around, save yer bucks.
...does not play well with others.
Re: Clutch Problem!
I believe he said the flywheel was cracked which means it should be replaced. Any reputable shop will refuse to resurface a cracked flywheel.
Re: Clutch Problem!
K. Didn't see where he said it was cracked, still seems kinda expensive.
Re: Clutch Problem!
hoooly crap dude,,,
i recently had to take a trip to the junkyard around GTA area for water pump and PS pump and outa curiousity i asked for these two prices too,
slave cyl. is 50 bucks and clutch master cyl is 30 bucks or more. The wreckers i checked were carcone's in newmarket and a wrecker in stoney creek(near hamilton),,
you are getting ripped off big time man, and definitely check out www.car-part.com , they have amazing prices listed there.
