I have a quetion, When you replace the water pump do you have to take out the timing belt? Is there other way to do with out taking out the timing belt?<p>
thanx.
need help
need help
92 Mazda Mx-3 V6 GS
Re: need help
it would be alot easier to take off the tim. belt, and than take off the pump. I tried to do with the belt on, and couldn't get it off... the belt is in the way
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Re: need help
There is no way you can replace the pump with the timing belt on.
