Need help guys! Starter issues I think
Hey guys i've been having this wierd problems with my mx lately. Sometime when i go to start it, i get power but the starter doesn't move. But if I wait a few minutes then it does, it's starting to do it more and more and i'm scared i'm gonna get stranded somewhere soon. Does this sound like a failing starter? or is it something else? any help would be good thanks.
Re: Need help guys! Starter issues I think
Sounds like a failing battery.
how would i find that out?
lay ur tongue across both terminals see if its charged
<p>hehe<p>nah just get a fluke metre that will tell you<p>alternativly if you have a friend just use his battery for a test and see if that fixes it when you start it up.
![Surprised :eek:](./images/smilies/icon_surprised.gif)
In
Eunos 30x, v6
KL-ZE, 2.5in exhaust, K&N intake
Unichip, LSD, 13lb flywheel, ACT2 clutch, NGK iridium Plugs, Top Gun Leads...<p>Goin In
Cams, Headers, TB, Extractors,
Bored to 2.8, Mazdaspeed Struts, Mazdaspeed strut tops,
Mazdaspeed swaybars, Eibach springs, Cusco Adj. Strut tops, Body kit, Altezza lights, Short shifter, Crossdrilled rotors and Calipers from AP racing, Braided brake lines, Braided clutch line, Mazdaspeed steering wheel, Mazdaspeed Leather shift knob,
Eunos 30x, v6
is there any stores that can check out a battery for me?
I would first check the battery terminals for built up corrosion. clean em up good then try starting. If its the same then test that battery.
If thats good, test the the starter.
Andy P. 93 GS
Andy P. 93 GS
Is there anywhere i can check out, to find out how to do these tests? Do I need a voltometer? Thanks.
do what andy says but also check where the wires are connected to the starter. it sounds like a bad connection
all i ask is that morgan die in a car crash
yeah thats what i was thinking it was a bad starter connection too.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Pedro:
is there any stores that can check out a battery for me?<hr></blockquote><p>I don't know if you have these in Canada but my local AutoZone performs battery tests and alternator tests.<p>Don't start replacing the starter until you're absolutely, positively sure that you have a good battery and alternator.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by andy:
Andy P. 93 GS<hr></blockquote><p>incase you forgot to read<p>![Wink ;)](./images/smilies/icon_wink.gif)
13.023 @ 105 mph
STARTER SOLENOID maybe? $33.99 autozone ![Very Happy :D](./images/smilies/icon_biggrin.gif)
well i disconected the battery and cleaned the terminals and it doesn't pull that **** on me anymore! so i guess it worked thanks for the help guys.
