Twin Turbo klze
BLINDMAN INC.
Twin Turbo klze
Post by BLINDMAN INC. »
Is there a way the intake could be split to have two seperate banks ? I'm asking this because I'm wanting to make a twin turbo klze.
Q187
Re: Twin Turbo klze
Post by Q187 »
There's always a way. The real question is do you have enough money to do it.
Talon_66
Re: Twin Turbo klze
Post by Talon_66 »
Search for this topic also, u'll find more
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
VizualXTC
Re: Twin Turbo klze
Post by VizualXTC »
Most likely you'd want seperate intakes for each turbo. I've seen some setups where the intake filter was connected directly to the compressor. I've also seen setups with 2 seperate cold air setups. If you break 1 into 2 it will only restrict airflow. I'd go with the 2 filter setup.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
