aproblem with and mx3 gs
i never had this before <BR>but now<BR>when im on nutral the idle is 500-600<BR>but when i shift it to any gear<BR>my rpm went up to 800-900<BR>does anyone know what is the problem<BR>please help me
Re: aproblem with and mx3 gs
mines always done that i don't think its a problem
- mitmaks
if u're not accelerating and it goes that low and almost wants to or does choke its your VAF rubber hose, probably has crack in it somewhere, inspect it and fix with some double sided tape
its only goes up to 800 rpm just when<BR>shift to any gear from nutral<BR>at nutral it on 500-600<BR>so can anyone help me
- Buff1110
there is no problem. my neutral idle is 300 and when in gear is like 600-800. at idle the engine has no load and when in gear, even though the clutch is still in the load is present but not engaged so the engine sorta gets ready by supplying more power.<BR>hope this makes sense<BR>Dan
Dan
02 Tacoma TRD - Daily
