check engine light on
manitobamx3
Post by manitobamx3 »
my engine light turned on last night cruisen around. There is also a hissing or whistling coming from the engine on the passenger side. Im thinking a hose cracked cause it just started freezing here the last couple weeks. Has anybody else had this happen or know what it is?
manitobamx3
Re: check engine light on
im thinking its a cracked vaccum line. No other opinions? [img]shrug.gif"%20border="0[/img]
Aston Wards
Post by Aston Wards »
Try the FAQ, there's a piece 'bout engine codes, but there's no harm in taking off your intake tubing 'n having a look for cracks! Seems to me it happens a bit, between the ridges mainly, just glue it back together
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
manitobamx3
don't think thats it its different but thanks for the help.
manitobamx3
Whatever its going to be it'll be looked at by mazda dealer tommorow. So im getting my wallet ready
Guest
Post by Guest »
i have to say screw dealerships! there are plenty of capable shops around that will do just as good work and charge you significantly less, although you have to be careful and find someone you can trust, i have an awesome shop and they bend over backwards for me, i take my car there and tell them whats wrong and they looik at it for free, so before youspend 400 bucks just to find out theres a 20 dollar piece ya need look around!
manitobamx3
actually thats exactly what i did an hour before reading your post. I found a shop that a couple other guys with mx-3's use and they are very fair and are known for good work. (This shop also done an engine swap for the best mx-3 in Manitoba). :D
David Coleman
Post by David Coleman »
David Coleman
manitobamx3
Code 16 came up when I did the check. 16 is Exhaust gas recirculaton system(EGR). What exactly is that and how would I find out whats exactly wrong with it? Whats required to fix this problem? Any help would be apreciated.
93mx3gs
Post by 93mx3gs »
You should try searching for egr and see what has been said about it in the past. Before I start a new post I always search beforehand.
manitobamx3
I did look in there and i even tried a home remidy of blocking up one of the tubes thats loose because of my cone air filter. But no go. So its going to the shop friday now (not the dealer)
