KLZE swap running rich
I have the MS8 intake manifold and ihave extra vaccum line holes and know where to hook them up i need pictures of some one with the same setup.
1992 MAZDA MX-3 GSR 2.5LTR V-6
2005 SUBARU STI
2004 NISSAN ARMADA
http://www.cardomain.com/id/wkdmx3gsr
http://www.netuners.com
2005 SUBARU STI
2004 NISSAN ARMADA
Re: KLZE swap running rich
If you have extras, just put caps over them.
I've tried putting caps on them the engine wants to rev up to 4000 rpms i've tried to connect them together also.
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
you sure its not something to do with your idle config? read the swap info on the main page and it tells you how to set it up so your idle is regular.<P>Tim Dawson
i need some really good pictures of the same ms8 setup. then i can see where everything goes. i really don't want to use the old 1.8ltr manifold because it makes a really big difference off the line when racing.
2005 SUBARU STI
2004 NISSAN ARMADA
2005 SUBARU STI
2004 NISSAN ARMADA
You should describe what exact vacuum ports you are referring to. Some people may help you without pics. Otherwise it will be too many. As for running rich, again -> ECU.
