Performance Clutchs for KLZE
Posted: October 11th, 2002, 7:26 am
by zevirii
Ok guys I need a Clutch arround or under $300 USD. Which of these is better?<P>ACT Z62-HDSS $305.15<P>or<P>CENTERFORCE Dual Friction $280<P>or<P>Clutch Masters Stage 1 10-026-HD00 $269.56
Re: Performance Clutchs for KLZE
Posted: October 11th, 2002, 10:56 am
by lazzyie
no centerforce, whatever you do, i have the act, somepeople say clutchmasters this is a toss up!! I guess get one and if you dont like it get the other, dont forget to get your flywheel resurfaced
Posted: October 11th, 2002, 2:07 pm
by David Coleman
Alot of the PGT guys who have had CM's for over a year now [since Rafi started selling them] are reporting slippage issues holding any forced induction on a regular KLDE [50 shot, turbo, etc]. Even on the Stage 3. I know Darin [highest hp internally stock KLDE] runs the same ACT clutch I have [the MX-6 V6 HDSS kit] and has over 300ft/lbs at the flywheel, no slippage....
Posted: October 11th, 2002, 4:03 pm
by zevirii
I thought the MX-6 version wouldn't fit because the sizes where slightly off for the 92-93's... Maybe that was just for the K8 and not the KLZE though... hmm so ACT would be better even though it is not a stage II...?
Posted: October 11th, 2002, 5:22 pm
by David Coleman
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by zevirii:<BR><STRONG>I thought the MX-6 version wouldn't fit because the sizes where slightly off for the 92-93's... Maybe that was just for the K8 and not the KLZE though... hmm so ACT would be better even though it is not a stage II...?</STRONG><HR></BLOCKQUOTE><P>Stages mean jack. The MX-6 disk fit my 93 just fine, and everybody else in the past who run MX-6 clutch discs because they're 10mm larger. You could get an MX-3 one for the same cost, and it would hold less. Your call...
Posted: October 11th, 2002, 5:24 pm
by C-MX-DA3
I have act it works great with the klze.
Posted: October 13th, 2002, 11:02 pm
by xxxxxroninxxxxx
i have the centerforce and i am very pleased
Posted: October 18th, 2002, 10:42 pm
by timpronk
I have a clutch masters stage 1 that I put in with my klze. I have driven it for over a yr and it still is working great. I had my flywheel machined before I installed it though. If I had more money at the time of installation I would have bought a higher stage clutch becouse its a pain to do it again with the engine in.
