california KLZE emissions
I want to do a KLZE swap and I live in California so I have to meet strict emissions standards. Is it possible to make this work?
Re: california KLZE emissions
Cali is not as strict as VA... You'll pass
Shaun Newman
California is not as scrict? Are you positive? We have the CARB which sets the standards for the US. As for the ZE passing, I dont see why not, I will see in July though
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
i'm sure... if anything its as strict as VA and my levels were extremely minimal.
Shaun Newman
make sure you swap the egr or you wont pass visual inspection
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
so the EGR is the only additional thing need?
well the egr system, including the vent/vac solenoids which are right behind the throttle body on the k8 manifold, so you dont throw up a code for the egr stuff on your ecu, as far as emissions goes yeah that should be all you have to swap, if you are looking for general swap info look at the swap section on mx-3.com
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
