valve cover oil leak.
66impala
Post by 66impala »
wife got car back from dealer and was told that the valve cover gaskets need replacing. this is a v6 and the forward bolts holding valve cover in place are leaking oil around heads. Is this something I can do? Looks like there should be a rubber o-ring under the head of these bolts?
lazzyie
Re: valve cover oil leak.
Post by lazzyie »
yes, but to do the rear you have to pull off the intake manifold, you can get the gaskets off of <A HREF="http://www.thepartsbin.com" TARGET=_blank>www.thepartsbin.com</A> for about $20 each, just read the online shop manual on <A HREF="http://www.mx-3.com" TARGET=_blank>www.mx-3.com</A> under the k8 engine, the torque specs are in inchpounds not footpounds
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
Mradio
Post by Mradio »
if you have all the necessary tools and some experience you should be able to do it.<BR>took me around 3hrs
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
