<p>[ September 21, 2002: Message edited by: killerpickle ]emmisions test - fail :(
killerpickle
Well, my emissions test was bad...no egr, though they seemed to think so ...<BR>Anyone have any ideas? Im thinking my cat converter...and maybe that the a/f ratio is too rich?<P>anyway heres a scan of the actual test - maybe this can help someone else in this situation, I heard about the "hot rod" test...what are the disadvantages to that? <P>
<p>[ September 21, 2002: Message edited by: killerpickle ]Tom Alexander
pelado
Re: emmisions test - fail :(
Yes, you're running way too rich.<P>You didn't mention a CEL, got one?<P>What ECU are you using? VAF?<p>[ September 21, 2002: Message edited by: pelado ]
killerpickle
Paledo,<BR>Thanks for the reply.<BR>Ok, I am running the mx6 2.5 ecu with the 1.8 VAF (Im almost positive.) Any way to check if its the 1.8 or the 2.5?<P>The only CEL I get is at highway speeds and it comes on only until I let off on the gas a bit then it goes away. (EGR?) Never a CEL under 100km/h...weird.<P>93+ octane gas<BR>Original Cat converter<BR>No EGR<BR>New plugs.<P>Dunno, I might have to go with the conditional pass to get my stickers renewed
Tom Alexander
Guest
i am having the same problenm with the engine light comin on around 120 and as soon as i let off it goes away! but also my virs isn;t hooked up right as it is not kicking in so i figuer it is jsut that! and i am gonna get that working tomorrow hopefully no more engine light
2.5 VAF will say KL-03 on it.
killerpickle
Hey Pawz<BR>let me know if that fixes the problem, I have the exact symptoms. Got a pic of your engine by chance?
Tom Alexander
pelado
Try running your 1.8 ECU with your 1.8 VAF for the emissions test.<P>My 2.5L VAF says KL02 on it, the 1.8 VAF says JE50.
