Mass Air flow sensor
Is there anyway to bypass or not use that sensor? Do you have to have it so the car will run? I have a 93 MX-3 1.8L and I'm wanting to install an air intake but the mass air flow sensor is in the way. HELP PLEASE!!
Re: Mass Air flow sensor
Look closer. The answer lies within the forum....(you need it)
94 Black MX3 GS Manual
If you have a 1.8 V6 than you have a VAF not MAF And no you cannot bypass it.
only way yo bypass is to convert it and change the mapping to accept a MAF sensor, look on Dave Coleman's site there is a good amount of links and info there
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
u can still have cold air set up with it on
