klze swap/aftermarket info
Posted: August 30th, 2002, 2:37 pm
by TedLeeper
hey I'm new to this side of the board beacuse i have a L4 1.6 dohc. but i was thinking about getting the klze<P>1 will it fit? <P>2 where can i find aftermarket parts for it. thanks
Re: klze swap/aftermarket info
Posted: August 30th, 2002, 4:41 pm
by nicolasbeique
like everyone will tell you;<P>you're better of getting a jdm 4cylinder engine like the bpt or the b6t.<P><A HREF="
http://www.corksport.com/" TARGET=_blank>
http://www.corksport.com/</A><P>(sorry if i got any info wrong, i pretty much only know v6 stuff)
Posted: August 30th, 2002, 5:05 pm
by Shadow_Mx-3
Read this: <A HREF="
http://www.mx-3.com/swap" TARGET=_blank>
http://www.mx-3.com/swap</A> <P>That's a great place to start your research on swaps.
Posted: August 30th, 2002, 5:26 pm
by voltaire
I don't know much about the 4 cyl. swaps either, but I think this would do the trick:<BR> <A HREF="
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 1855219836" TARGET=_blank>
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 5219836</A>
Posted: August 30th, 2002, 6:37 pm
by lazzyie
yes it will fit but... you need basically a donor gs model, for the wiring harness, drive shafts?, ecu, ac?, p/s pump?, vaf, it can be done just need the right parts, as for the 4cylinder swaps i believe kick a-- mazda has a do it yourself bolt on turbo DYI on his website, other wise i think you need a donor protege gt, good luck!
Posted: August 31st, 2002, 2:07 pm
by TedLeeper
do you think the jdm mx6 half cut from streetimports.com will get the job done? it has the kl-ze
Posted: August 31st, 2002, 6:59 pm
by curtklze
The drive shafts would be different. as well as all the motor and trans mounts and the cross members under the engine.
