klze swap/aftermarket info
TedLeeper
Post by TedLeeper »
hey I'm new to this side of the board beacuse i have a L4 1.6 dohc. but i was thinking about getting the klze<P>1 will it fit? <P>2 where can i find aftermarket parts for it. thanks
Hmm. what to do now..
....maybe a VTEC for lunch.
nicolasbeique
Re: klze swap/aftermarket info
Post by nicolasbeique »
like everyone will tell you;<P>you're better of getting a jdm 4cylinder engine like the bpt or the b6t.<P><A HREF="http://www.corksport.com/" TARGET=_blank>http://www.corksport.com/</A><P>(sorry if i got any info wrong, i pretty much only know v6 stuff)
<A HREF="http://www.spheregraphics.com/" TARGET=_blank>Image</A>
Shadow_Mx-3
Post by Shadow_Mx-3 »
Read this: <A HREF="http://www.mx-3.com/swap" TARGET=_blank>http://www.mx-3.com/swap</A> <P>That's a great place to start your research on swaps.
Jean-François
Now Mazda MP3 2001 Owner
The MX-3 is sold !
voltaire
Post by voltaire »
I don't know much about the 4 cyl. swaps either, but I think this would do the trick:<BR> <A HREF="http://cgi.ebay.com/ebaymotors/ws/eBayI ... 1855219836" TARGET=_blank>http://cgi.ebay.com/ebaymotors/ws/eBayI ... 5219836</A>
lazzyie
Post by lazzyie »
yes it will fit but... you need basically a donor gs model, for the wiring harness, drive shafts?, ecu, ac?, p/s pump?, vaf, it can be done just need the right parts, as for the 4cylinder swaps i believe kick a-- mazda has a do it yourself bolt on turbo DYI on his website, other wise i think you need a donor protege gt, good luck!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
TedLeeper
Post by TedLeeper »
do you think the jdm mx6 half cut from streetimports.com will get the job done? it has the kl-ze
curtklze
Post by curtklze »
The drive shafts would be different. as well as all the motor and trans mounts and the cross members under the engine.
Yes, I AM a bastard
