Port and polish
Max
Port and polish
Post by Max »
how much would it cost to port and polish intake manifold ? Port the exaust manifold and cylinder heads ?
VizualXTC
Re: Port and polish
Post by VizualXTC »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Max:<BR><STRONG>how much would it cost to port and polish intake manifold ? Port the exaust manifold and cylinder heads ?</STRONG><HR></BLOCKQUOTE><P>I imagine it's dependent on where you get it done. I'd call your local performance shops and ask them. I dunno, but I imagine it's not cheap.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
pelado
Re: Port and polish
Post by pelado »
There are some guys on Probetalk that state they PP intakes. However, what they are doing is PROBABLY basic stuff that is not supported by flow bench testing.<P>There are also some people stating they PP heads for a coupla hundred bucks. I would wager they don't have access to a flow bench either. They're probably doing some rather basic port matching and minor valve bowl work.<P>The last time I was curious about port work was after reading a great article about a small block Ford making some 350HP with heads from a well known shop. I called the shop and they wanted $1400 for port work identical to that in the article....I supply the heads. Needless to say, I didn't get it done.<P>Like Ryan said, it ain't cheap to have it done by a professional shop. And if the quote is cheap, then you can bet it is NOT being done by a professional with access to professional equipment!
FinaJet07
Re: Port and polish
Post by FinaJet07 »
Hey bro i'm takin my klze(before its installed) and getting it ported and polished at a shop that specializes in race cars, etc. and they do bad a-- jobs on my friends race car. They are doin it for $500, I think most places would do it for around that if you talk to them.
MAZDASPEED STEVE
Re: Port and polish
Post by MAZDASPEED STEVE »
First of all pelado knows his $hit!<BR>I know first hand that it cost me $2500Can ($1570.US) for a basic rebuild/and clean up of the heads and cylinders.<BR>Maybe Lance you might want to double check and make sure the shop knows that they'll be dealing with a 2.5L V6 Direct from Japan and not some 4cyl Honda engine. I just don't want you to get burned like I did. :)
THANX
MAZDASPEED
STEVE
FinaJet07
Re: Port and polish
Post by FinaJet07 »
bro there use to dealin w/ big block chevy's and dirt track race cars, the my little ol v6 shouldnt be a problem. sorry you got charge $1500. plus if worse comes to worse, i got to an auto-tek school and i'll just have the shop do it, so im all good either way.
ProtegeSTS
Re: Port and polish
Post by ProtegeSTS »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Lance:<BR><STRONG>bro there use to dealin w/ big block chevy's and dirt track race cars, the my little ol v6 shouldnt be a problem. sorry you got charge $1500. plus if worse comes to worse, i got to an auto-tek school and i'll just have the shop do it, so im all good either way.</STRONG><HR></BLOCKQUOTE><P><BR>your "little ol v6" uses totally different set of rules than V8s. The rod ratio is atmospheric compared to what they're dealing with and they are gonna screw it up. The guys you want to look for are motorcycle head specialists..thats the best youre gonna find.
-93 MR2
#129 E-stock
FinaJet07
Re: Port and polish
Post by FinaJet07 »
protege you are off the hook, why dont you go by an mx-3, and actually come to our world instead of just pretending. it seems like you have something smart to say about everyone's post. i'll leave it at that
Buzzin vee 6
Re: Port and polish
Post by Buzzin vee 6 »
If someone has something smart to say - listen.. when you know as much maybe your have something worth saying too.. An whoever said that a motorcycle place is the best is right, I had my old Mitsi FTO ported an polished with everything matched and they did a better job than anyone else I've heard of, not cheap but quality isnt always.
Dont stress at me, its not my fault your slower...
Ryan Bowen
Re: Port and polish
Post by Ryan Bowen »
I have to agree motor cycle performance engineering shops are the best place to go for this type of work. Some of them most likley are familar with doing jap import cars, this is the case with my uncle's well known shop in T.O. they use to only do bikes but now have converted mostly cars. The reason is that they make bikes so fast and powerful from the factory that the demand for engine beefing up has dropped, but it has moved on to import cars.......I hope this was helpful
