Would this work on mx-3
DDO49
Post by DDO49 »
I was searching for KLZE's and I came across this, supposively it's new so I was wondering what input you guys would give. Go to this link<A HREF="http://www.naplesnews.com/staff/fortier ... arger.html" TARGET=_blank>supercharger</A> <P> Image
G-Force body kit, 17 inch TSW's, custom sterio and soon swap for KLZE
mxer4eva
Re: Would this work on mx-3
Post by mxer4eva »
For the most part this is the same set up that Jeff Abrams has on his car, so if he was able to do it then im sure that you could do it aswell, considering you have enough time and money.
1993 GSR - Black with CS Mazdaspeed style front and sides skirts, KLDE and a bunch of other mods. Patiently awaiting a T3Super60, intercooler,MSnS and a custom fuel rail.
1993 VW Corrado SLC- completely stock. (May she R.I.P)
Zoso124
Post by Zoso124 »
280 whp? ya right, trying dumping the clutch at 4 grand, guess what? You just busted your axles. Yes this will fit in an MX-3. Check out Jeff Abrams <A HREF="http://www.mazdamaniac.com" TARGET=_blank>www.mazdamaniac.com</A> MUST READ! his SC is on a KL not ZE so he can run higher boost. Max boost you could run safely on a KL would be roughly 12-13psi, more than that your gonna destroy your bottom end. Oh for the supercharger and driveshaft about $3500 this doesn't include all the fun add ons and custom piping. Good luck.
Mike Evans
Gone:
