clutch ques.
Buff1110
clutch ques.
Post by Buff1110 »
i plan on doing either the klze or kl03 swap and most likely will swap the tranny. but i need a clutch soon so does the kl08 clutch work with these trannies or should i buy a clutch for an mx6 and will this fit for now?<BR>Dan
Dan
02 Tacoma TRD - Daily
white fish
Re: clutch ques.
Post by white fish »
the clutch will work but the clutch from the mx-6 is 10mm bigger look in to ACT clutches
pelado
Re: clutch ques.
Post by pelado »
No need to swap tranny unless yours has an auto and you want to go manual. K8 trans will bolt up to a KL block, no problem. Use the K8 flywheel, it's lighter than the MX-6/626/Probe one.
