white smoke
Re: white smoke
coolant
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Re: white smoke
i had this too, it was a coolant leak in my water pump<P>p.s. if you get that changed, get your timing belt checked while they're in there. It might save you some labor costs down the road
Re: white smoke
White smoke could also be burnin' oil. Bad rings, bad valve seals, etc. Usually burning coolant is a thin, whispy kinda almost steam. Is it SMOKE?
Jason B
1993 MX-3 GS
1.8 V6 5 speed
1993 MX-3 GS
1.8 V6 5 speed
Re: white smoke
black smoke= fuel, burning too rich<BR>blue smoke= oil, many possibilities from valve covers to rings<BR>white smoke= water, head gasket or cracked block
-Cody
Green '92 GS
140db on 1 12"
Green '92 GS
140db on 1 12"
